stefan
Start Edition
Does the Devkit also support ArchiCAD Start Edition?
E.g. can an ArchiCAD 19 APX run on ArchiCAD Start Edition 2016 (based on 19)?
I assume that you have to take care not to use methods that call into non-supported functionality (e.g. Publisher, ...).
Archicad-user since 1998
my Archicad Book
3 Replies 3
Ralph Wessel
Yes, I believe they're fully compatible (with the limitations you noted).
Ralph Wessel BArch
Central Innovation
stefan
I can confirm that we can run the add-in from ArchiCAD 19 on the Start Edition 2016 (without special re-compilation).
my Archicad Book
Akos Somorjai
There isn't any restriction on the API, but restrictions inside ARCHICAD do apply; and yes, please do not call any unsupported function (though you should get an error code if you do that...)
Best, Ákos
