The file is either not an Add-On or an outdated one that can
Hi recently I got a trial license of ArchiCAD. After that I cant able to load any add-ons. I had a look at the below link and fallow the steps mentions to load a add-on for a trial version of ArchiCAD. But no luck. Can any on one details explain step by step process.
3 Replies 3
Ralph Wessel
I highly recommend trying to build and run one of the example projects bundled with the API first. It's a good way to get started, and can be used as a benchmark if your own projects don't work.
Ralph Wessel BArch
Central Innovation
ReignBough
Based on my experience, this error message occurred when the compilation of GRC files has error.
Make sure that the GRC files are compiled correctly. To check: open the compiled GRC files (.grc.rc2) inside the Debug/Release folder on text editor (Notepad, etc.), if it is empty then it failed the compilation.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
dushyant
Yes, I can confirm that this was due to the GRC files not being compiled correctly.
