Archicad C++ API
User data Problem
hi,
I have create two addons.
The first based on Panel_test to set my user data and the second to read this user data for exporting data to external program.
The problem is that the data is not reading by second addons.
I have used as help Notification_Manager and Panel_test examples
thanks
gerry
1 REPLY 1
I think the reason for that is that the two addons have not the correct local ID
For each addon you must set the Add-On Identifier in the resources
like
'MDID' 32500 "Add-On Identifier"
xxxxxxxxxx
xxxxxxxyyy
xxxxxxxx is the Vendor ID
yyyyyyyy is the Local ID
Try using the AddOnAdmin Tool to create Local IDs which are in the same
Addon Group.
If iam wrong or any body knows it better pleas correct me
Regards
