howto use the magic-wand tool via the API?
Hi 🙂
Is there a way to use the magic-wand tool via API-calls?
Example-Situation:
There are several closed polylines.
The result of invoking the addon should be the same as the result after a user has manually clicked inside each polygon with the magic-wand tool.
I found a way to access the properties of the magic-wand tool (API_MagicWandInfo) but i have no idea how do invoke a magic-wand-operation.
Has anyone a hint whether there is a way to simplify polygons considering the properties set in API_MagicWandInfo?
greeting,
John
4 Replies 4
I have the same question, too.
Anyone knows how to use the magic-wand tool via the API?
Hay,
I was wondering the same.
Please let me know if you guys find out a way to use that
thanks a lot
+1 like
