using Polygon2DData-methods with a Hatch?
Hi 🙂
I want to use the geometrical methods of Polygon2DData to manipulate elements of type "API_HatchType".
Are there methods to sync the polygon-data of the Hatch (stored in API_Element.hatch.poly and API_ElementMemo) with the data of a Polygon2DData-variable?
Any hints?
regards,
John
1 Reply 1
Akos Somorjai
Hello John,
You are mostly on your own, unless someone has a working example. In the next devkit I may put together a basic example.
HTH,
Akos
