amitchristian
python for Unused Items in View Map
Python script for Unused Items in View Map only (available on graphisoft website) seem to work for AC24 version only.
If i run the same script for AC25 or AC26 version, script runs without error but returns empty folder. I have made sure by creating extra items in view map which are not setup on layout, but script still returns empty folder.
Anyone else facing this issue? Please let me know if any solution for the same.
I just tried this in AC26 and it worked without any changes. Are you still facing the same problem? If so, can you provide maybe an example file where this doesn't work so we can debug it.
Best,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
amitchristian
Thanks for checking. The script works fine now in all versions. Earlier issue was due to default publisher set with 1-Layout & 2-Views. Once these publisher sets were deleted from project, script worked fine.
