ā2023-02-24
05:53 PM
ā2023-05-09
02:47 PM
Noemi Balogh
I have a interior elevation rendering issue happening with BIMx.
The tile image used for the elevations renders fine when looked at in ArchiCAD, published pdf's, and even in the BIMx 3d fly through model. However when you go to the BIMx interior elevation sheet it doesn't render properly. I have attached images showing it in pdf, 3d and BIMx doc.
I have tried republishing and it hasn't helped and it does this on the IOS app as well as the web page.
Has anyone else seen this problem?
āāā
ā2023-02-26 12:27 AM
@Brad Elliott Have you tried reporting this through the iOS app or other feedback link. The developers are usually very good at responding to any problems.
ā2023-02-26 03:43 AM
Is this with the new release of BIMx?
ā2023-03-01 03:26 PM
Hello Brad, thanks for the report. We received your mail. The BIMx experts in the support team are investigating this export issue and will reply soon.
ā2023-03-20 05:15 PM
To update everyone, this is a known issue that will be fixed in AC27. Here's the current workaround.
As a cumbersome workaround, you can create two different textures for the distorted and for the non-distorted appearance.
The client went with a slightly different tile and the new pattern rendered fine so that was an easier work around.
