Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
ARICHICAD - CAD FILES - Google Earth (KMZ files)
How can i mix two files, one a DWG (Cad File) and a KMZ file (Placemark at Google Earth) in order to save it as KMZ file and open it with Google Earth. Is it possible? ..
1 REPLY 1
Link
AFAIK kmz exports only from the 3D window, so a dwg wouldn't be visible in the resultant file unless it contained 3D info. So you would probably have to open or save your dwg as a library part to see it in GE.
So, without testing it, I would think the workflow would be to place the dwg as a library part into the project, import the kmz file, then export them both out together?
Link.
