fuzzytnth3
ArchiCAD 21 IFC export is much slower than AC20
ArchiCAD 21 IFC export is much slower than AC20 and the file size it creates is now three times the size that it was previously. Also Solibri Optimizer app is failing to do its optimization to reduce the file size.
Anyone else come across this issue? If you did was there a way to fix it?
Looking at the Translators my Project is using it has only brought in an ArchiCAD 20 translator and it has none of the AC21 presets. The Project was converted from AC20 to 21.
Next problem is there does not seem a way to export the AC21 translators from the AC21 template file and I can't find them on my computer to import them into my Project???
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
1 Reply 1
fuzzytnth3
Well I have sussed one thing out. To Export you don't, it is saved with the PLN or Teamshare file, so from the PLN/TW point the Import button at the File you want to import it from and voila!
