Wokka
ArchiCad to Illustrator (ai) format for C4D
Hi all,
Does anyone know of a cheap way to save spline/polyline/line etc as an illustrator file? I want to take the basic outline of paths etc and extrude them in C4D. Unfortunatley C4D doesn't recognise 2D DWG but it does import illustrator files. I don't want to have to buy illustrator just for this simple export.
Any help or ideas would be great.
Cheers
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
4 Replies 4
__archiben
Wokka wrote:
Unfortunatley C4D doesn't recognise 2D DWG...
. . . but illustrator does
~/archiben
b e n _ f r o s t
Wokka
I know Illustrator does, but I don't own it. I'm hoping there's a shareware around that will convert dwg to ai files.
thanks
Lumion 12.5/2023
D5 Render
__archiben
thanks
shoulda read that more thoroughly.
have you tried using *.3DS as an intermediate format? instead of a polyline, you could draw a small polygonal wall and 'save as...' from the 3D window?
i have a vague recollection that there used to be a direct C4D exporter . . . i guess maxonform has knocked that on the head.
~/archiben
b e n _ f r o s t
Wokka
No worries.
I use the export direct from Archicad for 3D modelling and it works great(Maxonform is a bit of a sore point for me ) but what I need is basically 2D elements from Archicad into C4D. This enables me to map UVW textures etc directly in C4D with native splines/nurbs etc so I don't have to trace over 3D elements imported from Archicad.
If you don't use C4D it's a bit hard to explain the problem. Maybe I'm just getting lazy in my old age?
Lumion 12.5/2023
D5 Render
