Archicad 20 to C4D
Hi
When re-exporting an Archicad model to C4D (with Vray) for rendering, I've discovered that I cannot reference the previous file's textures, cameras, rendering settings etc. I had used the 'din3d' plugin on previous versions of Archicad (which was incredible btw) but this is no longer available for new versions. The current export plugin does not even 'tag' the Archicad model within C4D - further evidence that referencing was not considered in this plugin!?!?
What plugins do other renderers use for exporting to C4D - so one has the option of updating the Archicad model in the future?
Thanks for any insight
e
14 Replies 14
Good news. The exporter for archicad 21 is out.
win
mac
win
mac
Thank you!!
prot158 wrote:
rodut1112 wrote:
But still graphisoft has to improve this workflow.
What is worse, it's that the Din3d plugin is just the same (improved) as it used to be before. It was a paying add-on from graphisoft. Now it's free and useless
You're talking about maxonform, I guess...
Sorry, late answer.
Nope. MaxonForm is the origin of the actual exchange plugin.
Before there was that:
Hi
Din3D is available again. Check it...
http://din3d.net
