Archicad 9 / DWG Translator set up
I am trying to export a DWG file and cannot seem to get the translator to work properly. I am using the pen color conversion table but all lines show up as white in autocad. Is there anyone out there who could walk a fairly new user through the set up process. Any help would be much appreciated.
Are you crossing off the "bylayer" option under Attributes-pens and colours-methods?
This will cause everything in the Autocad drawing to be white unless you use a template dwg file with the layers set with colours and linetypes.
