Atom Array from Maxonform
hello, I have a project that uses truss like structure for the whole of the building envelope and got it done in maxonform, but when sending back to ac, it just takes toooo long to get it done and when it is done, opening the file takes a long time too (the polys are less than 20k), I think its the lines that are causing this. Is there any way to make this process faster? help...
edit: apparently it's much more faster to import the object from a .3ds file, but then is there a way to make the .3ds imported file like the one from maxonform? (projection lines etc.)
0 Replies 0
