Aaron Bourgoin
Autodesk Marketing Fiasco?
Ralph Grabowski is covering the story of a well crafted marketing ploy by Autodesk and the announcement of AutoCAD 2006.
see: UpFront e-zine and AEC News
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
3 Replies 3
Ben Odonnell
Aaron,
Thanks for the links.
Interesting, the attached image doesn't remind me of any thing though
One thing I do like though, is the on screen input. Slowly we see Revit like functions showing up in AutoCAD.
It would be nice to have the same sort of function/tool in ArchiCAD.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Seems like the command line interface is being ditched.
Not before time
Scott Davis
AutoCAD (and all AutoCAD based products) will have a new Dynamic Display, which can be used instead of the Command Line. But for those that have old habits that die hard....you can still turn the command line on.
Nice to see the new Text functions in AutoCAD, even if it is a bit like ArchiCAD (hey, we all learn from each other, right? ) Now I just need that text editor to be incorporated into Revit.....
Scott Davis
Autodesk, Inc.
On March 5, 2007 I joined Autodesk, Inc. as a Technical Specialist. Respectfully, I will no longer be actively participating in the Archicad-Talk fourms. Thank you for always allowing me to be a part of your community.
