Mats_Knutsson
Mentor
C4D/Maxon question about nurbs
Dear gurus.
I make a nice loft object and then I want to assign thickness to it and bevel the edges. WhaddoIdo?
I can do a surface with thickness by extruding a line and then apply operators on it but I would like do do it with a NURBS-surface.
AC 25 SWE Full
stefan
You can try to create a loft between closed contours instead of just splines.
You can also activate Caps and Roundings in the Loft object, but not sure that is what you are trying to achieve.
I know there is a 'shell' modifier in VIZ/3ds max that generates a thick object from a flat one 😉
Archicad-user since 1998
my Archicad Book
