Cadimage Tools on AC15 problem
I've been working on AC14 with the Cadimage tools.
The other day I finally updated to AC15 and also updated the Cadimage tools by downloading them and running the installer. As usual.
However, when I opened a project with AC15 and saved it (overwriting it to AC15), I noticed I can't adjust or even add any of the Cadimage tools (i.e. coverings).
It works fine if I open a blank project, so I must have ran into problems with loading the library on the existing project or whatnot... what else was I meant to have done after installing the Cadimage tools? Did I miss something? I've asked over at the Cadimage site but they haven't sent a decent response. It has been a few days and I'm pulling my hair out as my assignment is due soon!
Hope the problem makes sense...
Do you have the add-ons (goodies) installed for version 15?
I'm not sure but I think some of the Cadimage tools need the accessories add-on.
Go to the HELP menu in Archicad and click on the link for 15 Downloads.
Thanks - but apparently the AC 14 library was still loading so I had to remove it manually and add in AC 15 library.
Problem solved.
