Cigraph Architerra
Hi, I have problem with this program. I'm trying make the ROAD. First time I maked a terrain then I used Archicad polyline for making line. Then I selected terrain and polyline and click on ROAD. In this moment a have a problem, because I see window with text "The conditions do not exist to apply the command!!!" Please somebody help...
5 Replies 5
anyone know....
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Are you sure you really used a polyline?
Are you sure you selected the polyline and the mesh and nothing else?
If you answer yes to both this question then send me the file and I will checkl it.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
I think that there is a common mistake of users - work is performed with 3D-Mesh, but not with the terrain of Architerra.
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
If you want you can use also "normal" 3D Mesh (I mean mesh created without using ArchiTerra) but you have to convert them before:
just select the mesh and click on the ArchiTerra terrain icon.
This will convert the mesh into an ArchiTerra Mesh and will let you use also this one with our add-on.
Friendly
Fabrizio
Fabrizio Diodati
This is one of the really cool things about Architerra. Since it works with standard meshes it is very flexible and fully compatible with others who don't have the add-on.
