Double Doors
OK, I have seen this mentioned briefly before, but it's been a while so I'll ask again.
Can you schedule a double door to read (2) 3'-0" x 7'-0" in lieu of 6'-0" x 7'-0", ie. schedule the width and height of the individual panels that make up the total opening?
Thanks in advance.
1 Reply 1
I could not see any parameter that does that, maybe someone who uses the international library?
But in any case you can use a parameter in the Parameters for Listing and manually type your desired notation in an User Defined parameter.
Using Find and Select (in 3D) you can minimize your acts, by selecting by all affected double doors by name of the object or ID.
