IFC cannot write output file error
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-01-02 12:51 PM
‎2020-01-02
12:51 PM
I am trying to save a ifs file and i keep getting this error
"cannot write output file error"
I tried :
-saving as ifc and ifcxml
-saving only 1 element of the file
-saving with a simple name
-saving in desktop, server and dropbox
-rebuilding the 3d model before saving
-using archicad standard translators and my own
-opening a new file w default settings and saving a wall
-giving Archicad full disk access
none of this worked!!!
is anyone experiencing this? any solution?
thanks in advance
Luis
Solved! Go to Solution.
Labels:
- Labels:
Data Exchange
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-01-06 11:03 AM
‎2020-01-06
11:03 AM
Thanks for your answer.
The problem was that the path to the EDM folder was broken and also that I had to give Archicad not only full access to the harddrive but also full accessibility on the mac system settings.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-01-02 05:44 PM
‎2020-01-02
05:44 PM
What your translator ? https://helpcenter.graphisoft.com/user-guide/89325/
What is your aim ? https://helpcenter.graphisoft.com/user-guide/89335/
Do you check your element classifications before ? https://helpcenter.graphisoft.com/user-guide/89336/
Do you save your ifc model since a 3D view ?
An ifc is even more than a extension file. I invite you to check these points and tell us what you have done.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-01-06
11:03 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-02-06 11:56 PM
‎2023-02-06
11:56 PM
Having the same issues with my new MacBook and ArchiCAD26. Can't find where to set the "EMD-folder".... It's not to find in the dialogue "IFC Local Preferences"....
