Import excel to archicad?
Is it possible to import excel file into archicad?
because i need to do some calculation inside archicad, eg the costing for carpentry work, or archicad itself has something like excel can do calculation?
Thanks.
11 Replies 11
Jefferson wrote:
Is it possible as moderator a poll could be conducted, [they get more attention than just posts right?], asking for a community response to calculation ability, even modest, in schedules......?
There are at least two polls about this already:
http://archicad-talk.graphisoft.com/viewtopic.php?t=21689
http://archicad-talk.graphisoft.com/viewtopic.php?t=758
Hope I helped more than I confused, but it seems you found a working solution to your problem anyway! 🙂
davdelven
Take a look on this CADIMAGE post
http://blog.cadimage.com/2012/09/importing-keynotes-database-as-text-file-from-excel/
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
