Mesh and terrain
Hi, i'm new in the forum and working with archicad, i used to work with autocad, bus saw archicad and fall in love
I like to know if the is a way to conver autocad terrain level lines in archicad mesh?
Thanks
1 REPLY 1
Direct import of points files (or other AutoCAD generated terrain models) requires ArchiTerra. In ArchiCAD alone it is reasonably simple to use a 2D site plan (DWG or scan) and trace it to an ArchiCAD mesh. A search of the archives should turn up considerable material on this; including detailed methods.
