Relocate & Reuse a devoloped Finish Schedule
I've developed a detailed Finish Schedule in one of my larger projects. I now have the need to reuse that Finish Schedule on a different project. Is there a way to import that old Finish Schedule into a new project?
4 REPLIES 4
First you must Export it from the original job.
You will see an Export button in the schedule settings.
Then you can Import it into any other file.
The pull downs I created did't come with the import.
The image hopefully says it all.
I loaded (let's say) the format for the schedule & I had several items showing "MISSING". Once I went back & loaded the details (pull down information), it all came together. Thank you.
