archicad vs revit (in my opinion)
hey there, In my office I use archicad for everything...
6 months earlier I decided to try revit so i had revit 2011 and did some interesting stuff with it, and came upon these points about revit vs archicad
• Editing of shapes/splines (e.g. Slabs, fills, lines….etc):
Archicad: very easy! You just click on an edge or node and a spline editing toolbar appears, in archicad this is done very quickly.
Revit: you go into a 2d editing mode where you use 2d drafting tools (offset, trim, line, circle….etc) to draw the spline or the shape you want.
• Library parts Objects creation:
Archicad: I have to admit first that I had no training in this topic. Though it's very complex and knowledge-based and process to create an object or a lib. Part in archicad. Of course there are objects that you can create fairly easy like simple doors or so, but if you want to add parameters or functionality to you objects. There has to be programming and scripting done (e.g. creating something like the "Partition Panel "that has a number of panels and accessories on/off switches…).
Revit: I'm surprised to find that objects (families) creation in revit is something that is as easy as drafting... You just create a model, add dimensions, link/constrain them to specific parameters and make your object work like magic; actually, this is the most attractive feature in revit along side with it's 3d massing tools that is yet to be discussed.
I can say that archicad is a user friendly building modeler and non user friendly objects editor/creator. Whereas revit is a non user friendly building modeler (as to be discussed bellow) and a user friendly object creator/editor! Very strange fact...Eh
• 3d Modeling
Archicad: archicad's strong point is its flexibility. You can very quickly create a building model with high level of detail and finishing. However, there is organic architecture which is a zone that I cannot cross using archicad's modeling tools. Is NOT capable of creaing organic shapes whatsoever unless with a help of a 3rd party add on like cigraph's archiform.
Revit: wonderful!!!! I only have to say that I can play with these revit's massing tools in forever!
• 3d window 3d navigation
Archicad: 3d window use 'exploration' rather than 'zooming'. Archicad makes you feel like you are holding a camera and going through the model. There is the feature of 3d explore which I like to play with when I have clients in it impresses them and makes them understand the design better.
The 3d window uses openGL engine to enable the user to see raster materials applied to objects this helps a lot with the modeling and decision making.
The 3d modes are shading, wire frame, hidden line (internal engine only)
Shadows are enabled in openGL in version 14 which is great although I didn’t try it yet.
Vector patterns are enabled via the use of enternal 3d window engine.
Revit: Its default 3d projection is an axonometric view!!!! . I HATE axonometric VERY MUCH and I think that parallel projections are best suited for mech. Engineers or some industrial designers, its use in my opinion in architecture should be limited to descriptive views (sectional 3ds…etc). You can add perspective view via cameras which suks. To make it worse; the 3d navigation is via 2d zoom, meaning that you navigate in your model like you are zooming in a picture.
In the previous versions, the display of real textures preview in 3d window didn't exist up until version 2011 of revit, which had a big entrance via enabling not only the display of textures, but also the display of ambient occultation. There is also several display modes like hidden line, shaded with edges, shaded without edges
Vector patterns are present through all the versions of revit
To be continued………
43 Replies 43
• HELP AND SUPPORT:
Archicad:
-- HELP and Documentation: Natively installed with Archicad, you can find detailed description about everything; the nice thing is that you can find Interactive Training Guide for Archicad; which is rich and detailed and very important for you to learn about every feature in the program.
You can find detailed example files there. (Although they are the same for each and every version in Archicad); it would be excellent for newbies if there would be something like "Evermotion ArchiExteriors" You can find excellent training material in "Virtual Tutor for Archicad 12"
--Libraries and Object: installed with the program, complete library that has all the necessary object need for every type of buildings. There is some companies that offer extra content to extend the limits of the library.
Revit:
--help and Documentation: must be downloaded separately from Autodesk website. There is excellent books for revit to begin with like "Mastering Revit Architecture 2010", VTC training for Revit 2010 and Lynda Training for Revit 2010.
Libraries and Objects": Must be downloaded Separately from Autodesk website.??!! (I don't know why).there is Autodesk Seek website that I think is the best BIM content download website in the web, it is organized, easy download, has huge collection of industry standard objects (sometimes not only for revit; but for autocad also).I envy revit for something: I find most supported BIM models format is the revit's ".rvt".
galalhamadto wrote:
• HELP AND SUPPORT:
Archicad:
Revit:
Talking about help, the Revit Help must be the worse help I've seen in a software in a long time. Try to find something doing F1, good luck!
I agree with you. native revit help does not help at all!!
you can only have to pay for some 3rd party training package
"design refrom" website is the best for revit modeling.
the example files provided with revit library are empty files done with laziness..
graphisoft help system is the best for archicad. i think the most successful programs are those that ships with excellent help system.
yes Autodesk are very into "value added resellers",
i went and post this thread in AUGI. checkout what they had to say:
Archicad Vs Revit in AUGI
haha i love these things always end the same. Start off good then it just becomes the same as Mac vs PC,
i guess it comes down to...try both & pick the one you like best, then let's prey the IFC gets better 😉
I'm not sure what you mean. The thread seems to remain civil and pretty accurate so far. It's nice to see more people familiar with both programs and it looks like most are recognizing that their choice of one over the other is mostly due to greater familiarity or simple personal preference.
sorry i meant the way the one was looking on the other forum.....
i agree great to see a constructive break-down. it would be good to see a breakdown of the difference between how libraries/families work for each.
Yes I meant the other, Revit, forum as well. It seems pretty civil over there as well. I have found this to be true on both sides as long as no one starts flaming.
yes i probably jumped i just saw the: ep....Graphisoft supporters are invading...
