Rakela Raul
beams data extraction
When you add a beam to the middle along a wall, (and just norrower than the wall not to get into skins, elevations lines , etc) the beam is not recognized in the 'data extract. calcs'.
if you move the beam, 2 inches out the wall, those 2 inches get calculated only.
Am i doing something wrong ? or it is what it is
(make wall shorter, put the beam, place another wall on top of beam is not an option)
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
6 Replies 6
Anything to do with the strength of the beam compared to the wall?
Just guessing here.
If the beam is weaker and is being cut away in 3D then I would assume it would not need to be included in any calculations.
Rakela Raul
thanks Barry,
i'll tell you that lastnite, for the first time i played with the mac version of ac10, (loved it) and the first thing i did was to try this, and did work. (so shame on me)......but i promised i was shown 3 times this problem in the office and i agreed that didnt work....for sure i will check again and rt now.
be back for more shame.
Rakela Raul
just checkd again, and the mates in the office are right, the beam is not read inside the wall. as soon as the beam is moved a little bit outside the wall, th schedule picks up the volume just outside the wall.
soooo, the beam inside the wall IS detected as an element but not calculated
(and lastnite, on my fisrt mac experiience, just didnt see the bm volume as zero)
thx a lot
Thomas Holm
what happens:
- if you change material?
- if you change layer priority?
Rakela Raul
thanku Thomas,
I have to try that also but not a chance yet...will do tonite and let you know
first thing tomorrow....thanku again Thomas
Rakela Raul
what happens:
Wall and Beam Priority , that was my problem, i had it good @ home bad in the office ....Thanks everyone.
