door and window schedule
Hi! I have a window part from D3 Library part from "D3 Real Door+Window"
How can show it in the door schedule instead of window schedule?
In group and element classification already change it to door but still shows in window schedule.
Thanks
Thanks
Your window schedule is selecting objects based on the object being created as a window. You will have to remove this criterion and select the windows based on something else; you can use properties, classification, partial IDs, etc. Alternatively, you can use properties, classification, IDs, etc. to EXCLUDE objects from the schedule. If the D3 window is already showing properly on the Door Schedule, this might be a good route to get it off of the window schedule.
Richard
AC26 (since AC6.0), Win10
Thank you that was easy
