2026-07-15 11:37 AM - edited 2026-08-12 01:07 PM
Dear Developers,
From Archicad 30 the Add-On Manager will display the version of the add-ons on the Info area of the Available Add-ons panel.
How to set the version?
If you develop you add-on using the archicad-addon-cmake tools, then it's encouraged that you set the version, otherwise you get a warning if you leave the default "0.0.0" in. This works on both platforms, on Windows and Macintosh.
config.json
"version": "30.0.0",
If you use your own build system, like Visual Studio on Windows, or XCode on Mac, you can set the version in the native resources.
On Windows you can add a VERSIONINFO resource and fill the FILEVERSION field:
VS_VERSION_INFO VERSIONINFO
FILEVERSION 30,0,0,0
END
The fourth value, Build Number is not displayed.
On Mac make sure you fill the CFBundleShortVersionString key in the Info.plist:
<plist version="1.0">
<dict>
<key>CFBundleShortVersionString</key>
<string>30.0.0</string>
</dict>
</plist>
Happy coding!
Best Regards,
Tamás
