2021-12-09 05:45 PM - last edited 3 weeks ago by Molinda Prey
Hello together
(I am using macOS Monterey 12.0.1, year 2019)
since a few weeks I have the problem that the dialog windows "Open" and "Save as" in the File - Tab drag disproportionately in the width and I can not reduce the window, only in the height. To get to the executing buttons, I have to drag the window across the screen a few times until I get from the folder selection to the right options. This problem occurs with both Archicad 23 and Archicad 25 (but with no other programs) and is independent of whether I work on one or two monitors.
Can anybody help, does anyone know this problem?
Solved! Go to Solution.
2021-12-10 01:33 AM - edited 2021-12-10 01:33 AM
It is a known issue.
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
Someone here has posted what they call a quick fix.
I have no idea if it works.
