Cabinet Door Pivot Lines
How do I make the pivot lines of the cabinet doors to show? The pivot lines on one of the cabinets are drawn as an example. Thanks.
4 Replies 4
Many objects have global controls in the Model View Options.
You may find a setting for this there.
If so remember to save the change in the MVO schemes - otherwise when you change views you will just invoke the original scheme with the setting turned off.
This is a great question. From what I've seen, there are no model view options for cabinet door opening line. How are people doing this?
Cadimage cabinets display opening or pivot lines on the doors
If there is no MVO setting then I would hope that you have control in the actual object parameters.
This will all depend on the object you are using and if it has been scripted into it as an option.
Is it a standard Graphisoft object?
