Doors with customizable mullions
Are there doors with customizable mullions (ie number, spacing, location, size) similar to the "HV Custom " window sashs in the ArchiCad 8.1 library? The only options I see for door panels besides all the predetermined ones are the "HV-Grid" but no "HV-Grid Custom". Thanks in advance for any help.
David Rulon
Dell Athalon xp1500 533mb ram
Windows 2000
AC 8.1.0.1307
The H-V grid door panel has most of the same options, it just adds them under the Parameters when you select the panel rather than in the same area.
Select the door style you want (with the H-V Grid panel available) and select the panel. Expand the parameters section of the settings window and expand the "Door Panel" parameter. The grid options should show (they are hidden with the other panels selected).
Hope this is what you were after.
I see the "HV-Grid" option which I have used but not the "HV-Grid Custom" option that allows me to edit these mullion in the 3d-window and also in the elevation window (which I can do with windows). I want to have a door that does not have all of the muntins run through the entire panel (i.e. more lights on the top) in order to match my windows. Maybe I am not looking in the right place but I do not see this option in the parameter window. Thanks for the help.
David
