setting out
General Cost Estimate
If you do enough programming, by the end you might see the artificial bimbo floating down the river. Cost estimates aren't drawn up manually anymore; ArchiCAD generates them. They’re much better.
	For this small pilot project, the printout exceeds 8 meters in length. That should explain the level of detail.
From the "I" between the "B" and the "M".
	It’s on the computer.
	The database is already around 12 m, not counting what else I plan to add.
	No AI, no API, no Direct-Link. It’s all inside ArchiCAD.
0 Replies 0
