PBC & the renovation tool
Can anybody tell me how to get the connection to work using the renovation tool.
The attachment shows the horizontal wall with the brown fill is set to new.
The vertical wall is existing
They do not connect as they should, if I set them both to existing they clean up as they should.
4 REPLIES 4
This is the connection as it should be (almost)
DGSketcher
Legend
Works as expected in AC19 as long as the material priorities are set correctly.
sinceV6
Hi.
Perhaps you have the "Do not intersect" options ON for a certain renovation filter.
Look here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=50295&postdays=0&postorder=asc&&start=22
Best regards.
That did it, thanks.
