‎2009-11-1708:42 PM - last edited on ‎2025-02-0702:50 PM by Aruzhan Ilaikova
‎2009-11-1708:42 PM
Probably a weird one.... is there any way I get the hot spots to print out?
I've created a grid of levels and added lots of hotspots to the grid lines so that I can print it out and manually apply countour lines to a hard copy before plottng the lines back in Archicad.
Unfortunately, no. Hotspots do not print. You would need to make yourself an Object that would resemble a Hotspot. Then replace the placed Hotspots with instances of the Object.
