__archiben
penset attribute bug when copying from one file to another..
watch out!
copying a single line of text from a master sheet in one file to another results in the entire list of penset combination attributes taken into the second file!
this is particularly frustrating when you are copying from a converted AC9 layout book (with a million 'different' pensets) to a nice clean template file that you're in the process of making . . .
~/archiben
b e n _ f r o s t
Link
watch out!
Hehehe - you don't think it stops at just pen sets do you?
You obviously haven't checked your Profiles yet.
It'll also bring the Gradient Fills back in if you've deleted those, not to mention all the attributes it actually does use!
Link.
