Simple FM model using BIMx and QR code linkage
tada
Applying the method I learned from kotetsu-san in ”How to use Archicad", I made a simple FM model in BIMx.
When you read the QR code on an equipment with an iPad camera, you can jump to the equipment on BIMx.
Tapping the URL of the information embedded in BIMx, you can jump to the webpage of the equipment and find the equipment information.
Also, tapping the drawing URL of the information will take you to the folder in the company's Dropbox, where you can view the information on the equipment,
completed drawings and operation manuals.
Electrical equipment can be viewed in the same way.
If you want to take notes when you go to a site for maintenance, a folder called "Maintenance Records" is also prepared in the Dropbox folder, and notes can be taken directly from an iPad using Excel.
Of course, you can also view past maintenance records.
We also linked the finishing list to the zone information in BIMx.
The area of ceilings, walls, and floors, as well as various finish charts, let us know from BIMx.
I have also made it possible to jump to the as-built drawings.
When I was a site supervisor and went to an existing building to do maintenance, I used the information on the equipment, as well as the as-built drawings and the shop drawings.
I tried this idea based on my experience which it was difficult to find information for clients on equipment, as-built drawings, and operation manuals and so on.
Only with an iPad and BIMx , I can pull up various information on the building.
We realized that this would be a very efficient way to improve efficiency.
日本語:
タイトル:BIMxとQRコード連携をつかった簡易FMモデル
How to use Archicadでkotetsuさんから習った方法を応用し、BIMxでの簡易FMモデルを作りました。
設備機器に貼ったQRコードをipadで読むとBIMx上の機器に飛びます。
BIMxに埋め込まれた情報のwebサイトをタップすると、その設備機器のHPに飛び、機器情報が見れます。
また、情報の図面URLをタップすると、社内共通のDropbox内の指定のフォルダに飛び
設備機器の完成図書や取扱説明書が閲覧できるようになります。
電気機器も同様に見れます。
メンテナンスに現地に行った時のメモをとれるように
Dropbox内のフォルダにメンテ記録というフォルダも用意し、ipadからExcelにて
直接メモをとれるようにしました。
もちろん過去のメンテ記録も見れます。
BIMx内のゾーンの情報に仕上げ表をリンクさせ
天井、壁、床の面積や各種仕上げ表もBIMxから引っ張り出せることをしてみました。
また、竣工図面にも飛ぶようにしてあります。
これらは、私が現場監督時代、既施工物件にメンテナンスに行ったとき
機器の情報や、竣工図、取扱説明書などがお客様がすぐに見つけれず
苦労したことによる発想から試してみたものです
BIMxを入れたipad一つあれば、その建物のさまざまな情報を引っ張り出せます。
これが非常に効率化を図れることに気付きました。
