Add-on Manager: Param-o outdated ?
hi all,
was trying to get the Param-O Add-on running but Add-On Manager says:
The file is an outdated Add-On that cannot be used with this Archicad version.
I have AC24 3003 INT FULL and PARAM-O 0.3.2-preview
Thanks for any hint!
BR, Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
1 Solution
hello Minh,
sorry my fault.
I have AC24 3008 INT FULL and PARAM-O 0.3.2-preview.
I solved the problem.
I moved the apx to that folder:
C:\Program Files\GRAPHISOFT\ARCHICAD 24\Add-Ons\Extras
before it was here:
All good now - thanks!
BR, Florian
Go to post
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Florian,
Thank you for the question and I am very sorry about the issue!
PARAM-O can only run with Archicad 24. Here, you mentioned that AC24 is used, but the build 3003 is the first build of Archicad 23 (for AC24 it should be 3008). Therefore, I'm a bit confused what is the exact Archicad version are you using?
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
hello Minh,
sorry my fault.
before it was here:
BR, Florian
