2018-05-11 02:19 PM - last edited on 2023-05-23 04:37 PM by Rubia Torres
//initalize element/memo API_Element* element; API_ObjectType obj; API_ElementMemo* elementMemo; //API_AddParType** parType; elementMemo=new API_ElementMemo; element=new API_Element; //element pointer element->header.typeID=API_ObjectID; element->header.floorInd=0; element->header.hasMemo=false; //initialize obj obj=element->object; //set obj paramter obj.angle=0; obj.pos.x=0; obj.pos.y=0; obj.level=1; obj.libInd=1; obj.ltypeInd=1; obj.pen=1; //write back new object params element->object=obj; //create element err=ACAPI_Element_Create(element,elementMemo); WriteReport("Element_Create",err);this gives me
APIERR_BADINDEX -2130313114 81060066 The passed index is out of range.error.
GSErrCode err; //get loaded libraries GS::Array<API_LibraryInfo> activeLibs; Int32 embeddedLibraryIndex; err=ACAPI_Environment(APIEnv_GetLibrariesID,&activeLibs,&embeddedLibraryIndex); if(err!=NoError){ WriteReport("GetLibrariesID",err); } //Loop through libraries and find mep library API_LibraryInfo libraryInfo; GS::UniString libraryName; for (UInt32 i = 0; i < activeLibs.GetSize(); i++) { libraryName=activeLibs.name; if(libraryName.Contains("MEP Modeler.apx")){ //Found MEP library ACAPI_WriteReport(libraryName.ToCStr(),true); } }
2018-05-12 12:43 AM
Who can do API development?If you don't have that experience, a lot of time is going to be spent cleaning up basic programming errors. I'd recommend the following actions:
API developers have to be experienced in C or C++ programming language
2018-05-13 09:41 PM
element.header.typeID=toolboxItemPipe.typeID; //ElementTypeID element.header.variationID=toolboxItemPipe.variationID; //VariationTypeID element.object.libInd=libIndPipe; //library index3. Get the default memo for the initialized element (NoError)
err=ACAPI_Element_GetDefaults(&element,&memo);4. Verify the memo additional parameters and those looks just fine. DumpParameters implementation from the Docs. (Working)
DumpParameters(element.object.libInd,libPart_Pipe.typeID)5. And here is problem i try to create the element with these initialized parameter, but it gives me an error.
err=ACAPI_Element_Create(&element,&memo); APIERR_REFUSEDCMD -2130312312 81060388 The passed identifier is not subject to the operation.Here is my whole code:
API_LibPart libPart; API_LibPart libPart_Pipe={}; API_LibPart libPart_PipeBend={}; API_ToolBoxItem toolboxItemPipe={},toolboxItemPipeBend={}; Int32 i, count,libIndPipe=0,libIndPipeBend=0; GSErrCode err; GS::UniString libPartName; //Found out which library elements ID for mep elements... err = ACAPI_LibPart_GetNum (&count); if (!err) { for (i = 1; i <= count; i++) { BNZeroMemory (&libPart, sizeof (API_LibPart)); libPart.index = i; err = ACAPI_LibPart_Get (&libPart); if (!err) { libPartName="Pipe Straight 20"; if(GS::UniString (libPart.docu_UName)==libPartName){ libPart_Pipe=libPart; libIndPipe=i; err=ACAPI_Goodies(APIAny_GetLibPartToolVariationID,&libPart,&toolboxItemPipe); if(err){ WriteReport("APIAny_GetLibPartToolVariationID",err); }else{ WriteReport("toolboxItemPipe.typeID",toolboxItemPipe.typeID); WriteReport("toolboxItemPipe.variationID",toolboxItemPipe.variationID); } } libPartName="Pipe Bend 20"; if(GS::UniString (libPart.docu_UName)==libPartName){ libPart_PipeBend=libPart; libIndPipeBend=i; err=ACAPI_Goodies(APIAny_GetLibPartToolVariationID,&libPart,&toolboxItemPipeBend); if(err){ WriteReport("APIAny_GetLibPartToolVariationID",err); }else{ WriteReport("toolboxItemPipeBend.typeID",toolboxItemPipeBend.typeID); WriteReport("toolboxItemPipeBend.variationID",toolboxItemPipeBend.variationID); } } } if (libPart.location != nullptr) delete libPart.location; } } //Define element API_Element element; API_ElementMemo memo; //TODO for cycle to read data from CSV line by line //Clear element, memo BNZeroMemory (&element, sizeof (API_Element)); BNZeroMemory (&memo, sizeof (API_ElementMemo)); //initialize element.header element.header.typeID=toolboxItemPipe.typeID; //ElementTypeID element.header.variationID=toolboxItemPipe.variationID; //VariationTypeID element.header.floorInd=0; element.header.hasMemo=true; //initialize element.object element.object.libInd=libIndPipe; //library index /*element.object.level=0; //height from the floor element.object.pos.x=0; element.object.pos.y=0; element.object.angle=0; //element angle */ WriteReport("element.object.libInd",element.object.libInd); //Get memo Defaults err=ACAPI_Element_GetDefaults(&element,&memo); if(!err){ //Element_GetDefaults was successfull //Get default parameters double a,b; Int32 parCount; API_AddParType **addPars=nullptr; err=ACAPI_LibPart_GetParams(libIndPipe,&a,&b,&parCount,&addPars); if(!err){ WriteReport("Parameters count",parCount); //write default parameters to memo memo.params=addPars; //parCount=1; //DumpParameters(element.object.libInd,libPart_Pipe.typeID); for(i=0;i<parCount;i++){ if ((*memo.params).typeMod == API_ParSimple) { DumpOneParam ((*memo.params).typeID, (*memo.params).name, (*memo.params).flags, (*memo.params).value.real, (*memo.params).value.uStr, 0,0); } } //try to create the element err=ACAPI_Element_Create(&element,&memo); if(!err){ //element successfully created ACAPI_WriteReport("Element created",false); }else{ WriteReport("Element_Create",err); } }else{ WriteReport("ACAPI_LibPart_GetParams",err); } }else{ WriteReport("Element_GetDefaults",err); } ACAPI_DisposeElemMemoHdls (&memo);
2018-05-13 10:08 PM
2018-05-14 04:41 PM
paramOwner.libInd = element.object.libInd; paramOwner.typeID = element.header.typeID; paramOwner.variationID=element.header.variationID; paramOwner.guid = element.header.guid;2. open parameters (NoError)
err = ACAPI_Goodies (APIAny_OpenParametersID, ¶mOwner, nullptr);3. Created an array of structure to hold the required parameters, and fill that
typedef struct parameter { char name[32]; short ID; double value; } parameter; parameter param[1]={}; strcpy(param[0].name,"MEP_StraightLength"); //that is the parameter name. param[0].value=2; param[0].ID=10; ...4. Get active parameters (NoError) and change them (NoError).
err = ACAPI_Goodies (APIAny_GetActParametersID, &getParams, nullptr); chgParam.index = param5. close opened parameters with success. And set memo.params to the new params. clear mask. Looks fine.ID; CHCopyC (param .name, chgParam.name); chgParam.realValue = param .value; err = ACAPI_Goodies (APIAny_ChangeAParameterID, &chgParam, nullptr);
err=ACAPI_Goodies (APIAny_CloseParametersID, nullptr, nullptr); memo.params = getParams.params; ACAPI_ELEMENT_MASK_CLEAR(mask);6. Call the change with undoable command... It appears on the previous menu but nothing changed on the element...
err = ACAPI_CallUndoableCommand ("Change Element", [&] () -> GSErrCode { return ACAPI_Element_Change(&element, &mask, &memo,0,true); });So I don't know whats wrong. Maybe you know something about this element. I tried to change a length(MEP_StraightLength) i can modify from the GUI, but not from the addon, but there is no error under runtime...
2018-06-12 10:58 AM
