JGoode
Stop regular 2D hotspot from extending object
I have a standard "hotspot2 a, 0" in my object. How do I stop the user from being able to select and drag the node to adjust the object size? I also tried to set the hotspot to _A (as I made _A = A) in the hopes that there would be a disconnect but I still have the issue.
Thanks
ArchiCAD 27
Windows 10
4 Replies 4
Lock A and B in your script
JGoode
I'm not able to lock A and B as I utilise these in the object. The issue is that when the regular node is dragged and changed, it doesn't trigger the "glob_modpar_name" in my script which also changes B to maintain proportionate sizing.
ArchiCAD 27
Windows 10
If You do not have actuall hotspots on the say 0,0; A,0; A,B; 0,B then the stretching by those will be impossible, same to ZZYZX in the space.
Peter Baksa
Set it up as a 3-part hotspot which edits "A".
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
