cyrdl
Can someone help me convert this file ? Archicad 28 to Archicad 27
Hi, someone send me an archicad file from Archicad 28 but I have only Archicad 27 and I can't open the file... can someone with Archicad 28 help me concert the file in Archicad 27 please ?
hère is the link for downloading the file : https://www.swisstransfer.com/dl/01a06b71-281c-712a-b6f6-bad475c5a27a
4 Replies 4
Can't you ask the person that sent you the file to save it as version 27?
It is probably best that they do it.
I am assuming you don't have a license for 28, or you could install that.
cyrdl
Hello, no I don't have any contact with the person...
I tried to install the 28 but my computer don't have the requirements for it so I'm blocked on 27 😞
OK so I am seeing red flags.
How do we know that you should have that file if you don't have contact with the person that sent it to you?
And 28 runs on the same machine as 27.
Andreas81ch
Hi cyrdl,
We have AC 29, 28, 27, 26, 25.
I saved this version to AC 27:
https://www.swisstransfer.com/dl/01a06c28-e550-7302-a543-35f2739c2a3e
PS:
This is school version (EDU) ONLY!
Message start ArchiCAD:
GER:
Sie haben ein Projekt aus der Archicad Bildungsversion geöffnet. Archicad schaltet nun in den Modus der Bildungsversion, solange dieses Projekt geöffnet ist.
FRA:
Vous avez ouvert un projet issu de la version d'éducation d'Archicad. Archicad passe désormais en mode éducation tant que ce projet est ouvert.
ENG:
You have opened a project from the Archicad Education Version. Archicad will now switch to Education Version mode as long as this project is open.
ArchiCAD v6.5 - 29 (CHE Swiss Edition / Schweiz) - macOS / WIN - Workstation in office: mac OS 26.5.1, Apple M2 Max, 64 GB RAM
