2026-03-11 03:47 PM
Custom fills are a simple yet powerful way to give your drawings clarity and add a unique character to your designs. Whether you’re creating repetitive patterns, textures, or importing images, Archicad offers flexible tools to make your elements stand out. This guide highlights practical workflows to create symbol and image-based fills that you can reuse throughout your projects.
When the default fill textures don’t match your vision, symbol fills allow you to turn your custom 2D patterns into reusable fill elements. Here’s how:
Draw your pattern on any 2D window.
Select the entire pattern, then copy it using Edit > Copy or the copy shortcut.
Go to Options > Element Attributes > Fills and click New.
Your custom symbol fill is now ready to use anywhere in your project.
Archicad also allows you to create fills from images, ideal for textures, logos, or more complex patterns:
Navigate to Options > Element Attributes > Fills and click New.
Name your fill and select Image Fill.
Under Appearance, click Browse > Add to upload your image.
Using image fills opens endless creative possibilities while keeping your documentation clear and professional.
| Create symbol fill task | Draw pattern > Copy > Options > Fills > New > Symbol Fill > Paste | Turn your 2D drawings into reusable fills |
| Set fill type | Drafting / Cover / Cut | Define where the fill will display in your project |
| Adjust pattern | Modify unit size & pattern | Control scale and appearance |
| Create image fill | Options > Fills > New > Image Fill > Upload image | Use external images as fill patterns |
Custom fills are an easy way to add a personal touch to your project while improving clarity and readability. Explore symbol and image fills to give your drawings a distinctive edge.
