Archicad 10 iTraining Guide: Marquee Selection Tool
Hi, I´m working on AC10 Guide Chapter 04_11, when I tried to use the Marquee selection tool and see it in 3d, it doesn´t work, just make the complete 3D.
Then I´ve tried on a new project with AC10 and also doesn´t work the marquee. Is there any setting on 3d window that I am missing?
Please Help.
Regards,
David Welsh
Check that you're using "Show selection / marquee in 3D" (F5 by default) and not "Show all in 3D" (Ctrl+F5 default) when going to your 3D window.
Stuart Rose, thanks for the clue, I have by default Show Selection with (F4) and Show everything (Command+F4), and I found a way to change the shortcuts in Opciones/Entorno de Trabajo/Esquemas de Atajos/Atajos de Teclado
Regards,
David Welsh
