Archicad 11 versus My PC
Hello,
I’m a student using Archicad 11 on Windows XP SP2 and I have many problems with 3D. To zoom and to rotate the buildings is extremely slow; the same the rendering. Even to open a project takes a lot of time…
I use DirectX 9.0c and the driver for video card seems to be okay, I recently downloaded it from NVIDIA. I have to mention that I have a 24” monitor and the resolution is 1920 x 1200 (32bits).
I replaced the 512 MB system memory with 2GB and still no improvement. I even went to an IT shop with my computer and I tested another video card having 512MB RAM and I saw just a little improvement, but far away from a normal behavior.
My system is:
AMD Athlon 2.3 GHz
Asus A7N8X-E
2 x 1GB (dual channel)
Leadtek GeForce4 MX 4000 - 128MB RAM
Please let me know if I can check something else, if I can tune somehow the settings in order to save ~ 1000 $ for a new machine! (
Thank you.
3 Replies 3
The 3d window is powered purely by the graphics card, so I would suggest that the graphics card is the weakest part of your system. This will have no effect on rendering speed though. It is a slow process anyway, limited by the processor speed and number of cores.
You say you tried a 512Mb card instead? Do you remember which model, as the amount of card memory doesn't necessarily translate into speed.
Any up-to-date middle-of-the-range gaming graphics card will be more than powerful enough for AC. Have a look on any computer hardware review sites and see what's available. Try tomshardware, for example.
I do believe in miracles now!
I downloaded a new driver from NVIDIA (93.71_forceware_winxp2k_english_whql) and everything works fine! Computer's world is very very strange...
Thanks God for inspiration, otherwise I was decided to spend those 1000$ on a Core 2 Duo & Co.
Glad you got this fixed. Remember that you can always use the marquee to outline a much smaller part of the building for the 3D view, which will render and navigate much faster.
Richard
AC26 (since AC6.0), Win10
