Key not Found Windows 7
I installed ArchiCAD 10 on a new Windows 7 computer. I was able to get it to install by loading Java 6.21, but it gave me an error saying the wibu driver was not loaded because it was not signed. I downloaded and installed the new driver from the ArchiCAD website, but when I open AchiCAD I get an error saying "Protection key not found or not valid (1050017). The key works fine on the older computer. Is there something else I can to do to get it to work?
3 Replies 3
Are you sure that you installed the correct choice of 32 bit or 64 bit driver, based on your version of Windows 7?
Is your Wibu key a Codemeter key, or the original colored plastic Wibukey? If Codemeter, see the Enabler download at the bottom of the page:
http://www.graphisoft.com/support/archicad/downloads/WIBU.html
Is your Win 7 machine an Itanium one? if so, see the note on that same page for the special drivers here:
http://www.wibu.com/en/downloads-user-software.html
HTH,
I got it straightened out. Windows needed some updates. I installed them and it is working fine now.
Thanks you.
Great. Hopefully your experience will help someone else in the same spot who reads this.
