MG2
Laptop Hardware
Hi all, I realize that has probably been asked but have been unable to find.
I will be upgrading to AC 28 and need a new laptop to run it. I was looking at an MSI Katana 15 HX B14WGK-248CA.
It is a gaming unit but does have an
  • Intel® Core™ i7-14650HX
  • Windows 11 Home which I will upgrade to Pro
  • NVIDIA® GeForce RTX™ 5070 Laptop GPU w/ 8GB GDDR7 VRAM
  • 32 GB RAM
I work on both small and medium sized projects. I can also get a model with the RTX 5060 but not sure if the slightly lesser graphics card will make much of a difference.
Any thoughts would be appreciated.
mthd
Hi @MG2, You may have already had a look at these specifications but here is the link for AC28 general system requirements. They might help guide you.
https://www.graphisoft.com/resources-and-support/system-requirements-28/
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
scottjm
Mentor
That looks more than adequate I would say for small to medium.
If the 5060 is a significant savings I’d take it. For only Archicad use the 5070 is probably overkill, but if you are using escape or twinmotion etc the 5070 is probably worth it.
