Researching HP 110plus, nr printer, vs Mac Tiger
I have begun shopping for a wide format printer. The HP 110plus nr, with roll feed sure seems to fit the bill. We will be relatively low volume users but need the size, it will go to 24"x36".
But does it work with Tiger, and AC 9.0 and Plotmaker?
Anybody?
3 Replies 3
i have this printer and it works great w/ tiger on a mac. i have v 10.4.2
archicad, plotmaker fine except for one problem. when printing 24"X36" you have to trick the page setup into printing it so that its in landscpe format coming out of the printer. its a pain you will have only once in setting up your master sheet in plotmaker. then all is fine.
i'm very happy with it.
donald mac donald
g5 mac v9.0
Ah. Good news. Thank you.
I'm assuming the 110plus is the newest HP in this catagory? (I didn't do the research.) And, that it's the best value for a relatively low volume user as we will be?
Have OSX 10.4.4; DesignJet 110plus nr;
Works great, except…
If I have a (somewhat) blank template sheet, with a text block on the left bottom corner, and along the right side the titleblock with many text blocks, and no drawing imported into the center of the layout…
The titleblock is shifted to the center of the layout.
Any ideas??
(Dual 2GHz Power PC G5,
2.5 GB DDR2 SDRAM)
Build 2172 USA)
