Here is what I found in my hard drive directory.
In the AC 10 folder is a folder called WIBU.
In this folder is one file called WibuData.tar.gz
last modified April 15 2006. Apparently not overwritten.
This file is a gzip compressed file and does not have a version number.
In the AC 12 folder is a folder called WIBU.
last modified June 26 2008. Apparently not overwritten.
In the Applications folder there is folder called
WIBUKEY that was created when I installed the
new WIBU-KEY drivers and inside are three files,
UserHelp.app, WkConfig.app, wkuMacX, and
one folder called Server. The files and the folder
all have the same modification date Oct 23 2008
Which is the date I downloaded and installed the
new drivers.
Inside the Server folder are five files,
Daemon Start.command, Daemon Stop.command,
WebMonitor.app, WkServer.log, and WkSvMacX.app.
These files have the same modification date,
Oct 23 2008.
Some of these files have the version number 5.21
I do not know if this version number is the latest.
I was careful to ask my re-seller to direct me to
the exact file I was to download because I was
sure there were many files on the Wibu site and
I would not know which one to download so I
would suggest you talk to your re-seller  to
make sure you download and install the correct files.
I did not re-install AC 12 or AC 10.
Peter Devlin
