2nd newbie question (corner windows)
Hi again,
I'm almost embarrassed to post twice in succession. Believe me, I did do the tutorial (some months back) and I have searched the forum.
The question is how to place a corner window?
I only have an empty corner window in the ArchiCAD library folder.
I'm assuming it's possible to put a frame and glass in there, or do I have to venture into GDL already?
Thanks again,
Steve
Mac OSX, new installation of ArchiCAD 9
4 Replies 4
if you select the corner window tool from the tool palette you should be able to use any standard window from the library
bill
Confused.
If I select a window from the library within the corner window tool and apply it to the empty opening, I get two separate windows, as the attached jpgs show. What am I doing wrong?
The 2nd jpg is here.
Ta,
Steve
Bizarre. Tried it on another machine and it works ok.
Challenge is to figure out why the first machine didn't work.
Thanks anyway for your help.
Steve
