2013-02-2010:55 PM - last edited on 2023-05-2611:18 AM by Rubia Torres
Adjusting window sidelight parameters
2013-02-2010:55 PM
I'm trying amend a window with sidelights either side.
I know the door leaf size (762 x1981) so I set this in the window settings.
I then want to be able to drag the sidelights to the correct size whilst retaining the door leaf size.
At the mo, the only way I can see to do this is by manually entering the sidelight width into the parameters.
Is there a way to select the handle and drag it??
It depends on the library part. If it was written for dynamic sidelight adjustment then yes, otherwise no. If yes there will be distinct hotspots in plan and/or 3D for the purpose.
