Any Military GDL
Does anyone have GDL U.S. Military vehicles that I can buy? Please respond back by Private Message. Thanks.
5 Replies 5
Why do you need native GDL? There are plenty of good military models in the Google Warehouse. If you have access to SketchUp Pro you can export as 3DS. If you need to rotate the tank turrets you can save them separately from the track/chassis. The 3DS import even gives you parts with detailed control over the materials (though it can be a trick figuring out which is which).
With a native GDL, I can load it into Archicad immediately. I bought a hummer DXF and it took about 1 hour to translate into Archicad.
Point taken, but if you can't find them that doesn't help. If you can get 3DS the conversion process is quick.
Rafal SLEK
I have M1 Abrams and Jeep Wrangler converted years ago from 3DS meshes.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
Rafal SLEK
... and Imperial Tiefighter from Star Wars too 🙂
Best
Rafał
