Archicad 12, how to add new materials
I have instaled on my hdd textures but when i manual duplicate material and change texture on 3d it is good but when i try photo render it changes material to original one,
What is right way to add new material.
And how to use custom picture for Carpet and TV
6 Replies 6
rocorona
If you do the photorendering with LightWave, instead of the internal engine, you have to do the settings for it too.
In the Material settings, disable the box "Disable unused controls" (well, something like this...) then open the LightWave panel, and hit the button "Match internal engine".
This is the simplest way, but you can play with a lot of settings.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
David Maudlin
rocorona wrote:
LightWave
Or LightWorks
For the TV object (like PlasmaTV 12), the image you want to use must be in the loaded libraries.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rocorona
David wrote:
rocorona wrote:
LightWave
Or LightWorks
Writing late at night causes the word "Work" very difficult to type
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
Thanks i Have found it. I have to click button Match with internal engine.
and i have using LightWorks.
Thanks for the TV but pic has to be 340x225.
Is it same for Carpet
rocorona
Not for me. I can use images of any size.
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
from where have you downloaded this textures?
How to add a new material, when i download a texture file?
