Display malfunction of Graphisoft ID dashboard
Learn more
Blank preview window ???
Hi.
I get a blank preview window at the properties of any object I open.
What is wrong???
AC11 WinXPpro DualCore 6600 2G Ram ATI XT1950
3 Replies 3
I also get a
"Fill not found at line 201 in the 3d script of file Casement_a.gsm" error message.
I am a newby but didn't have this problem with AC10.
vfrontiers
Sakatack wrote:
Hi.
What is wrong???
Apparently this is a KNOWN BUG that whenever you go to the Object Dialog, then hit the ENTER KEY, the preview disappears. If you use your mouse on the OK button, this doesn't happen. Only fix now is to restart AC... Should be on for the next hotfix.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Thanks vfrontiers.
I have been told of an other trick.
To lower the acceleration of my monitor.
It worked for a couple of times but the bug came back again.
(like cockroaches) 😉
